纪念一代大师,看看什么才是真正的建筑结构+结构建筑
2013-12-15 00:29 发布
404 14 0
全部评论14
  • zsrck88
    zsrck88 2013-12-15 00:29:09
    楼主能不能详细的介绍一下这个建筑?
  • e8xlmyr
    e8xlmyr 2013-12-15 00:29:09
    大师就是大师!
  • fnjr7kn
    fnjr7kn 2013-12-15 00:29:10
    大师就是大师啊,让我们现在看到了也想不到啊
  • qi1hzo1
    qi1hzo1 2013-12-15 00:29:10
    Exhibition Building, Turin Commentary
    The Creator’s Words
    "...two of my most interesting projects, the hangars built of pre-cast elements and the roof for the Turin Exhibition Halls, would have been impossible without a simultaneous invention of the structural method. They would have looked completely different if they had been built on the same principle but in a conventional technique."
    — Pier Luigi Nervi from the Introduction of Jürgen Joedicke. The Works of Pier Luigi Nervi. pVII.
    Details
    "The hall is rectangular and covers an area of 240 feet x 309 feet. On one of the two shorter sides is a semi-circular apse. Windows are arranged in the corrugation of the prefabricated roof elements."
    "A semi-circular apse 132 feet in diameter adjoins the main hall which is 240 feet long. Its roof consists of corrugated pre-cast units. The half-dome roof of the apse is also constructed with prefabricated elements."
    "The vaulted construction of the hall consists of prefabricated elements which spring from in situ concrete abutments."
    "The units are of "ferro-cement" and have a length of approximately 15 feet and a width of 8 feet 3 inches. The thickness of the curved precast parts is less than 2 inches. This small thickness is achieved only by the increased rigidity through the corrugation and the transverse webs at either end. The individual units are joined by in situ concrete."
    — Jürgen Joedicke. The Works of Pier Luigi Nervi. p59-62.
    Details
    Updated to serve as ice hockey venue for 2006 Winter Olympics in Turino.
  • grdj3k8
    grdj3k8 2013-12-15 00:29:10
    这种图 施工单位看了会骂娘的!
12
