澳洲urban collective公司建筑2012 设计竞赛 获胜2000美金
2013-08-08 13:23 发布
353 9 0
设计竞赛具体要求 http://urbancollective.com.au/design-challenge/
如有 不懂问题 可以加 qq 215186173 或者直接登录以上网站询问设计细节。
标准模块建筑2012 设计竞赛 奖金2000 美金
Let's harness modular construction techniques to combat the housing affordability crisis in Australia – design a contemporary modular home!
要我们治理模块式建筑的施工技术去解决澳洲住房难得危机吧- 设计一个当代的模块式家。
Open to all architects, engineers, designers and students – individually or in groups, throughout the world. The competition opens on Tuesday 14th February 2012 and closes on Friday 20th April 2012.
世界各地所有的建筑师,工程师,设计师和学生 - 个人或团体都可以参加。竞赛开放时间是(星期二)2012年2月14日,并于结束于2012年4月20日(星期五)。
We'll judge the submissions and select three finalists. The submission with the most ‘likes’ on our URBANCOLLECTIVE Facebook page will determine the winner, who will be announced on Monday 30 April 2012 and awarded $2,000.00USD in cash!
我们将裁判的上交作品,并选择三个入围。上交作品在URBANCOLLECTIVE的Facebook页面以最“喜欢”的将决出胜负,公布2012年4月30日(星期一),并获得$ 2,000.00美元现金!
The Challenge
URBANCOLLECTIVE challenges the architectural, engineering and design community to design a contemporary modular home; to create an affordable and livable space to increase awareness of the possibilities for modular and prefab construction.
Modular and off site construction has widespread use throughout the UK and Europe with up to 90% of single family residences being prefabricated or using modular structures. Despite increasing interest, most average Australians underestimate the design potential, the eco credentials and the cost saving and other benefits of choosing off-site construction over traditional site built construction methods.
URBANCOLLECTIVE’s Modular Building Design Challenge 2012 aims to not only further dialogue within the design community and build interest about prefabrication and modular design but also to create contemporary and affordable modular designs to aid in combating the widely discussed housing affordability crisis in Australia.
A long-held Australian dream is home ownership, which is fast falling beyond the reach of many with the median house price continuing to rise, primarily on account of strong demand and limited supply. Though governments have implemented measures directed at improving affordability these have been largely directed at housing policy, models of financing, planning regulations, land supply, infrastructure funding and taxation. Little appears to have been written or done about the role of design and alternative construction methods in the provision of affordable and sustainable housing, though design is one of many factors influencing these critical issues.
The Brief
We’re not looking for your stereotypical, temporary or bland houses. Instead, we want designs that are daring, functional, contemporary, affordable and preferably green. A design that you would be proud to call home…or live next door to….
As this is intended as an ideas competition (and there is no specific site details prescribed), there is no expectation that submitted designs adhere to any specific planning controls. Instead, designs are invited that propose contemporary and functional modular solutions, that provide good amenity for residents and the surrounding neighborhood.
The minimum design requirements are: 最低设计标准需求
Use of contemporary design features; 用现代的设计特色
Successful integration of energy efficient and sustainable design features; 成功的结合能源的有效性和建筑的可持续性设计特色
Use of modular construction; 用模块的施工方法
The mandatory dimensions for each modular component of the design is 每个组成模块应用强制的的尺寸
Standard Module Type 1 标准模块型号1
12,192mm long
2,438mm wide
2,896mm high
12.192米长
2.438米宽
2.896米高
Standard Module Type 2标准模块型号2
6058mm long
2,438mm wide
2,896mm high
6.058米长
2.438米宽
2.896米高
Please note: 请注意
The modules must be kept whole in the design. 该模块必须保持在整体设计
Submissions must include at least two Type 1 modules. 上交设计必须包含2种 型号1
Submissions can include a combination of Type 1 and Type 2 modules, but the use of Type 2 modules is not mandatory. 上交设计可以包含型号1和型号2的结合,但是型号2不是强制使用的
A maximum of two Type 2 modules can be used in the design. 最多可以应用2个种类2 模块
The standard module types are such as to keep within the limitations for international shipping and limitations of road transport (without requiring escorts).1 To this end, designs may use multiple modules/portions (meeting the overall width limitation) in combination with each other to create a wider or longer design. Modules can be stacked vertically to allow the house to be completely or partially double storey.
The design uses a steel frame structure (to enable it to be lifted for international shipping and transportation);
标准的模块类型,以限制内保持国际航运和道路运输的限制(无需护送).1为此,设计可组合使用多个模块互相/分配(满足整体的宽度限制)结合每一个模块式去建造一个宽的或者长的设计。模块可以垂直叠放允许的房子是完全或部分的码放2层。
本设计采用钢架结构(使其能够做为国际集装箱进行吊运和运输);
The design combines all important functions including:
Sleeping – minimum of 2 enclosed bedrooms;
Living – living/dining;
Cleaning – Bathroom and laundry facilities;
Eating – Kitchen; and
Car accommodation – either garage or carport for 1 or 2 vehicles.
The total design area is a minimum of 59.4m2 (or two Type 1 modules) and maximum of 118m2 (or four Type 1 modules), excluding any car accommodation.
设计结合了所有重要的功能包括:
睡眠 - 至少2个封闭的卧室;
客厅 - 客厅/饭厅;
清洁 - 浴室及洗衣设施;
饮食 - 厨房;
车库 - 1或2辆汽车的车库或车棚。
总设计面积最小是59.4平方米(或两个1号模块)和最大的118平方米(或四个1号模块),不包括任何车库面积。
The design is intended for use within Australia (for guidance purposes only. It is up to entrants to specify if the design is particularly suited to a particular sub climate i.e. arid or tropical climate).设计用于在澳大利亚的使用(仅供指导。是根据参加者对于设计指定一个特别的适合于一个特定的区域,即次气候干旱或热带气候)。
These are the minimum requirements for your design. All other design considerations or variables are open to your own creativity and imagination. Go for it and mix and match to suit!!!
这些是您设计的最低要求。所有其他设计考虑因素或变化对于你自己的创造力合设想是开放的。去参与设计吧!!
全部评论9
