关于对于面积求和和长度求和,还是有很多用途,在这里写一个lisp程序。 加载程序,在命令行运行am 选择你要求和的物体,可以是line ,circle,arc ,ellipse ,spline, polyline,mline等,算出面积和长度。 指定位置和高度,就可以用文字标注出来。 (defun C:am (/ ss l i totalarea ename obj entarea) (if (setq ss (ssget)) (progn (vl-load-com) (setq modelspace (vla-get-Modelspace (vla-get-activeDocument (vlax-get-acad-object)))) (setq l (sslength ss) i 0 totalarea 0 totlength 0) (repeat l (setq ename (ssname ss i)) (setq obj (vlax-ename->vla-object ename)) ;;(vlax-dump-object obj T) (if (vlax-property-available-p obj "area") (setq totalarea (+ (vlax-get-property obj ’area) totalarea)) ) (if (= (cdr (assoc 0 (entget ename))) "MLINE") (setq totlength (+ totlength (ml-length ename))) (setq totlength (+ totlength (vlax-curve-getdistatparam ename (vlax-curve-getendparam ename)))) (setq i (1+ i)) ) (setq text1 (strcat "总面积为: " (rtos totalarea 2 4) "平方毫米") text2 (strcat "总长度为: " (rtos totlength 2 4) "毫米") ) (if (setq insertpt (getpoint "\n请输入文字插入点: ")) (if (setq height (getdist "\n请输入文字高度:")) (setq insertp1 (vlax-3d-point insertpt) insertp2 (vlax-3d-point (polar insertpt (* 1.5 Pi) (* 1.5 height))) textobj1 (vla-addtext modelspace text1 insertp1 height) textobj2 (vla-addtext modelspace text2 insertp2 height) ) ) ) ) ) (defun ml-length (ename / j d ptlist) (foreach n (entget ename) (if (= (car n) 11) (setq ptlist (cons (cdr n) ptlist)) ) ) (reverse ptlist) (setq j 0 d 0) (repeat (1- (length ptlist)) (setq d (+ d (distance (nth j ptlist) (nth (1+ j) ptlist)))) (setq j (1+ j)) ) d ) http://abbs.cn/pic/2007/01/03/1167811566.rar ......................................................... ☆ 12ouiuqg 回复: 没看懂怎么回事? |
